Where is your compressor mounted? If it's the monster York thing on the right side that surrounds the fuel pump, then all the engine threaded holes on that side are M8x1.25. If its mounted down low on the header side, those four threaded bosses on the block low down are M10x1.5mm    As to length, get your tape measure out....
zKars  I saw an older post where you had installed the GEN two mini I was wondering if you had pictures of the brackets you use to mount the unit under the dashboard and if so what metal used and where I could purchase that metal ?
Im going to be doing an install as soon as the damn eBay person ships the vintage air unit. Your best bet for the mounts is just to make them out of a thin bar of steel. At least that's what it seems that everyone else is doing.
Up until the last one, I was making the brackets from scratch.
The last though I used bracket arms from vintage air.
https://www.vintageair.com/brackets/
Then attached them to a plate I made that fits the four M10 block bosses.
