Any suggestions for trouble shooting the parking brake light.  It does not illuminate when you pull on the parking brake.  Have checked the connection and seems ok.  All dash lights were recently changed.  How do you check the voltage and where?  What fuse is the brake line on?  Have changed all fuses but no luck.
https://www.classiczcars.com/topic/60384-parking-brake-light/
Does the light work on for anything else? If not go back the the bulb. If it lights for anything else check the ground at the lever in the center console.
72 body with 71 interior, Eibach, Illumina, R180 CLSD, 83 close ratio, 3.90 gears, Zstory, SUs, BRE Libre wheels and front spoiler.
  • Who's Online   1 Member, 0 Anonymous, 1,554 Guests (See full list)
