I am not a pro mechanic, I started on this project z ‘75 280z fuel injected. I changed all the gaskets and realized I needed new fuel injectors. I pulled them and changed them. I didnt relieve the pressure by disconnecting the line and letting the pump pump it out. I leaked some fuel and relieved the pressure that way. I replaced everything and put the car back together when i went to turn it on it wouldnt turn on.
It cranks and if i give it gas it tries to turn on but wont stay on. I think i have spark. When i have the key in the on position i can hear the fuel pump working. My gas tank currently has under a quarter of gas. And before i change all the spark plugs and wires how can i make sure if its the gas pressure or if it isnt getting enough gas. I changed the fuel filter too. What should i do to run diagnostics? Thank you!
https://www.classiczcars.com/topic/60561-fuel-problems-spark/
Did it run when you started the project?
Try starting fluid.
Make sure that the intake manifold and crankcase are fully sealed.  All of the injector o-rings, the oil filler cap, all ports on the manifold must have a hose or be blocked.  Even the dip stick tube has to be sealed.
Try starting fluid.
It ran. I will try starting fluid. Im sure everything is sealed but ill double check.
1 hour ago, ajmcforester said:
Also check wire connections to pump, injectors and ignition
Sent from my [device_name] using http://Classic Zcar Club mobile
I havent gotten a chance to work on it but... i did an egr delete would that have anything to do i disconnected a wire im guessing it was to a water temp gauge could that be giving me an error? All the pipes were sealed and headers installed
Not what I'm thinking old cars sometimes a wire connections don't always connect after disconnecting.
Did you plug the one under the throttle body that comes off the EGR or BPT, I can't remember which but it's the one circled in yellow in this photo.
Here's a good picture of the connections on a "77.  Thanks to @240260280
His write up,
http://atlanticz.ca/zclub/techtips/electricalconnections/index.html
Edited by siteunseen
His write up,
I plugged upthe one for the egr. I gotta check the wiring again i will be changing the spark plugs and wires anyway
The temp and thermostat sensors were in a plug together with the egr. Ill try pluging that in maybe thats why it isn’t starting?
  • Who's Online   2 Members, 0 Anonymous, 1,393 Guests (See full list)
