Looking for the following parts or advise from those that have barked up the tree!
I have too much free travel in my clutch to allow me to adjust the clutch. The bolt that holds the pedal in place and creates the fulcrum (p/n 46561-21000) and the sleeve that fits over the bolt (p/n 46582-21000) are nla....trying a work around with a bolt I picked up, but it is still not the proper diameter and causes too much free play.
Any advice is appreciated.IMG_20180813_091513449.jpgIMG_20180813_091455178.jpg
Sent from my [device_name] using http://Classic Zcar Club mobile
https://www.classiczcars.com/topic/60569-71-240-clutch-pedal-parts/
Thank you for the quick reply. I have a bolt that works and even the bushings that go into the pedal, but am looking for the sleeve that goes over the bolt and through the pedal shaft.1534203818922
This is the picture showing bushings already installed. There is a sleeve that fits between the bolt and these bushings.
McMaster Carr is easy to order from.  Very quick.  they've even improved their web page so I can paste links now, and get fairly close.
https://www.mcmaster.com/#bushings/=1e57wtr
I'd go for drill bushings.
Edited by Zed Head
GV Z Car I just spent the evening looking for bushings that will work without having to machine them.  I have found some from asbbearingsonline.com that measure 15mm ID x 19mm OD and 16mm long.  These will work with the 12mm x 15mm stainless tubing I have to replace the sleeve with.  Should receive the bushings in a few days and will let you know if they will work.
I probably have one or two of the bushing the OP is looking for? Please PM me...I am terrible remembering this stuff, so if you want it, keep trying to get a hold of me.
It also looks like he clevis pin hole needs to be welded up a re-drilled.
Edited by David F
