There does not seem to be tested and confirmed numbers that I was able to find. I have seen the chart at http://www.geocities.com/MotorCity/2824/heads.html but it does not have the combination I was looking for. Does anyone know factually what the compression ratio is for an F54 block with flat-top pistons and a P90 head combination is?
https://www.classiczcars.com/topic/6058-compression-ratio/
