Sometimes when you let the clutch or brake pedal up quickly and they hit the stops you get that metal spring echo sound in the pedal box, I found by stuffing some dense foam up the length of the spring you can get rid of a lot of the sound.
I would think the screaming engine and tire noise when you drop the clutch would hide those noises! Hahahaha
I got onto the Century Spring website the other day when I was looking and printed off the relevant pages for similar springs from their pdf catalog. They were supposed to be annotated for long hook springs etc. I never could find the annotation. They probably make the correct spring or one very similar if you could locate the correct number in the catalog
12 hours ago, SoCalJim said:
Mark, it doesn’t have the wide open ends like the original part (see Patcon’s Picture), however, it does go on with a little help from needle nose pliers.  I have an extra spring if you’d like it.
@SoCalJim I'm sure Jai would appreciate the spring. I'll PM her address to you. Thanks.
PM sent
  • Who's Online   1 Member, 0 Anonymous, 1,222 Guests (See full list)
