hi all
i want to go one key for my car which is 2 keys at the moment.
i also need to change my ignition switch.
i am looking for complete set but can't find it except at a crazy price on ebay.
do you have any adress ?
do you know if some other datsun or nissan cars lock set could match ?
thanks
https://www.classiczcars.com/topic/60681-new-lock-set/
From the OP post I don't know what year car we're talking about, but...
My '71 is also a two key affair. The ignition key is toothed on both edges, but the door / hatch key is only toothed on one edge. the cut lines down the key sides appear to be very different. I can't see how the locks could be made to work with a single key for the whole car by a locksmith. My '73 was keyed to a single key of the type with the teeth on both edges. Not sure when Datsun changed to the single key for the whole car, but it was sometime between 12/70 when my '71 was built and sometime in the first half of '73.
https://www.classiczcars.com/topic/60681-new-lock-set/#findComment-556609
My 4/71 build has the double edge cut key that works on all locks as well as the ignition.  One key does it all.
Dennis
Edited by psdenno
https://www.classiczcars.com/topic/60681-new-lock-set/#findComment-556627
  • Who's Online   2 Members, 0 Anonymous, 1,157 Guests (See full list)
