I know I have a few 240 models, which fit and work, but need to have wiring adaptation done. You will also loose the 'empty' warning with the early sender as it doesn't have the extra sensor.
Let me see if I have a 280 sender. Would of course be better.
 Check it for elec. continuity first. Whee was the one that told us about soaking sending units in CLR. I've saved a couple of sending units using his tip. The worst one had good continuity but was rusted up solid. Nothing would move. That one took 48 hours in CLR.  It came out looking good and worked great.
On 10/3/2018 at 6:15 PM, rcb280z said:
Anything is better than spending $250 for a rebuilt one, that's for sure.
I think I read once that the tractor sending unit will work, you just have to bend the float rod a bit?  Mine leaks... I just keep it below 3/4 tank for now.  Or maybe it was a forklift?
Edited by ramsesosirus
  • Who's Online   0 Members, 0 Anonymous, 1,485 Guests (See full list)
