Hello out there...
I am re-installing my front suspension after a long floor pan (and lots of other rusted metal) replacement. Should I use STAINLESS nuts, bots, washers for any and all areas where needed...? I love stainless, but not sure if Grade 8 would be a requirement for suspension components. Any comments would be appreciated.
Thanks...Ryals
https://www.classiczcars.com/topic/60892-suspension-hardware/
You definitely shouldn't be replacing grade 8 with SS and yes there are grade 8 bolts in the suspension system. SS although quite hard is not very strong, it looks pretty but it reacts with other metals just as easily as zinc covered bolts.
