So I am having a hard time with my front 71 front bumper. I have sent it off to be re plated by a local plater. However it has always seemed to flexing like someone hit something head on. The plater is having a hard time bending back to what I think is normal. So my question is to you guys, is it normal for the front bumper to be 1 1/2 in or so away from the mounting holes ?
https://www.classiczcars.com/topic/60894-bumper-woes/
22 hours ago, jfa.series1 said:
NO!  The bumper should be nestled right up to the body - about 1/8" (no more than 1/4") away from the body.
Curious about the gap, I measured it on my '71Z.  Drivers side .22" and passenger side .75".  The bumper has probably been off and on a dozen times since 1971, but no collision damage to the bumper or the car.  Soooo, now I have a project - mess with mounting points until I get 1/2" on each side.  Might be a winter project when I install the new bumper rubber strips.
Dennis
  • Haha 1
https://www.classiczcars.com/topic/60894-bumper-woes/#findComment-559238
@joe newsom - I took another look at your pics, specifically the pics showing a look down on the hood.  The bumper should exactly parallel the leading edge of the hood all the way out to the headlight buckets and it seems yours does not.  I cannot come up with an explanation as to how your bumper opened up the "V"  but its possible the problem begins at the center point.
https://www.classiczcars.com/topic/60894-bumper-woes/#findComment-559250
[mention=31908]joe newsom[/mention] - I took another look at your pics, specifically the pics showing a look down on the hood.  The bumper should exactly parallel the leading edge of the hood all the way out to the headlight buckets and it seems yours does not.  I cannot come up with an explanation as to how your bumper opened up the "V"  but its possible the problem begins at the center point.
Yep I thinking the same
https://www.classiczcars.com/topic/60894-bumper-woes/#findComment-559270
I wonder.. is it possible that you miss these parts?  (I've got these for sale..) They are used on some USA 240z cars?   this is not a european car part for as far i know..   I've seen them on ebay (feebay)  for 100 euro  and in bad condition.. these are almost like new, or as they say:  in super beautiful and perfect condition...pfff... ( the rubber is after all this time (in storage for more than 25 years..) still soft and in good condition.)  (At first i thought it were wrong ordered new parts, but you can see were a nut or bolt has been sitting so they are used i guess but in great condition.)
Are these used only on '73  US. cars?
13 hours ago, Pop's Z said:
That gap looks like it might be a '73 bumper. Mine has rubber inserts where you have gaps.
Are these those "inserts?
https://www.classiczcars.com/topic/60894-bumper-woes/#findComment-559280
I had this same problem when I converted my 280z to the 240z bumpers.  The rear fit great, but the front had this same gap, even though it lined up from the center.  I don't know what  year the bumper was... but my solution was the cut a "V" in the very center of the bumper (on the top and bottom), align it on the car and "bend" (massage) the bumper until it was pretty flush.  Then I welded the new "V" together (it later broke, due to my incorrect welding technique but that's another story).
I painted the bumpers black since the chrome was faded anyways, so it's not really visible.
https://www.classiczcars.com/topic/60894-bumper-woes/#findComment-559648
  • Who's Online   0 Members, 0 Anonymous, 1,417 Guests (See full list)
