I replaced my fuel rail and installed some green top Injectors into my 1981 280zx. When trying to crank it 6 puffs of smoke (one per injector) came out from the injectors ports. Do the injectors have little seals around them that I forgot to Install?? Im not sure what to do. I did notice a gap between the hole for the imjectors and the Injectors themselves. Any ideas?
https://www.classiczcars.com/topic/61121-injector-issues/
Aleigjty! I think I'm missing the little o rings like y'all linked and sent pictures of. I'll pull off the fuel rail and injectors and get a picture of them.
On a side note. On the blue ECU plug under the dash, there is a 2 pin plug with a yellow solid wire (I think) and a yellow worth red stripe wire. When I replaced the harness I failed to note where that plugs in. Any ideas?
Thank you for the help
https://www.classiczcars.com/topic/61121-injector-issues/#findComment-562109
