260Z Will fire with starter, quits when key is released.
74 (early) 260Z, It turns over fine and will fire when started is engaged. As soon as the key is released it dies. I heard this may be the ballast resistor. Any  suggestions would be appreciated. I need to get this car winterized, but must get it to run again, before that happens.
Edited by Jeff Z
misspelled word
44 minutes ago, SteveJ said:
Do you have a multimeter or test light?
Not accessible to me right now, so no. Do you suggest I go get myself one?
Edited by Jeff Z
added to message.
Get at least a test light.
Turn the key to On.
Clip the wire on the test light to chassis ground. A common point is one of the bolts on the shock tower.
There are three wires on the ballast resistor: white/black, black/blue, and black white. With the key in the On position, you should have voltage at the black/white wire. It has the arrow next to it in the picture
Lift the cap on the black/white wire and touch the pointer of the test light to the wire.
If the test light lights up, lift the cap on the white/black wire (opposite side of the resistor from the arrow) and touch the test light to that wire.
If you didn't have a light on the black/white wire, you have a loose/bad connection or bad ignition switch. You might want to talk to me on the phone about tracking that down.
If you have a light on the black/white but not on the white/black, you have a bad ballast resistor. You can move the black/white wire to the same terminal as the white/black, but you shouldn't run it long that way.
I had the same problem on my '71 240Z.  Car would crank and start fine but as soon as I let the key return to the "ON" position it would die.  I replaced the ignition switch thinking that was the most likely source of the problem but it didn't make a difference.  I finally tracked it down to a loose/dirty connector on the ballast resistor.   I removed the connectors, cleaned them real well, and made sure they were nice and tight when I put them back on and everything works fine now.  I believe on the 240Z the ballast resistor is bypassed when in the START (ie. cranking) position but comes into play when the key returns to the ON position.  I haven't looked at the 260Z electrical diagram but I would imagine that it might be similar.
  • 4 weeks later...
I finally got time to get back out there and it turns out one of the posts on the resistor is loose and comes right out. I am assuming this is the problem. Does anyone know where I can find a replacement for this resistor? Or should I do an upgrade?
Jeff
The 260Z ballast resistor is NLA. You might be able to get away with a 240Z ballast resistor. You would have to move the start wire over to the same terminal as the coil wire.
The problem with that is that I don't know why they introduced a small amount of resistance in the starting circuit. If you're worried about that, there is a kludge I could describe to you, but it's not very elegant.
  • Who's Online   2 Members, 0 Anonymous, 1,468 Guests (See full list)
