I am trying to find a good replacement for the gas tank drank plug and washer. Does anyone know where to get them? My washer is disintegrated and the bolt has a slow leak and I am not even sure it’s the correct plug.
https://www.classiczcars.com/topic/61222-78-280z-fuel-tank-drain-plug/
Pretty pretty pretty sure that somebody out there knows the thread pitch and  size but here's a link to the Nissan part numbers.  They call it a plug and packing.  Talk about translation problems.
http://www.carpartsmanual.com/datsuns30/Datsun-Z-Index/Engine-280Z/Fuel-Tank/From-Jul-76
BIG EDIT Sorry about this but the 1/2"x20 is completely wrong, You are looking for an M8x1.25 bolt.
I was looking through my notes and 1/2"x20 is what I have there but that must be for something else, I just went out to the storage shed to dig out the gas tank. A 1977 280z gas tank has M8x1.25 drain bolt.
Note to self, re check my notes :facepalm:
Edited by grannyknot
5 minutes ago, Patcon said:
I also found it to be a standard thread and not metric. I found that odd but didn't fight it.
Actually, I'm still trying to find mine, I removed it when I was restoring the tank and put it somewhere safe, so safe it still hasn't shown up, I may have to make one.
Don't you hate it when you do that! I have a roll pin I took out of something. Put it in a conspicuous place in the shop so I wouldn't lose it.
I still have it, but I forgot what it came out of....:facepalm:
33 minutes ago, ryanotown22 said:
Well the plug is still available but it looks like but the “packing” is NLA. what should I use to replace the washer? (Correction both are NLA
@ryanotown22, my apologies, see post #3.  Forget the 1/2"x20 that is completely wrong, my notes are wrong. The drainage bolt you are looking for is a M8x1.25,  I just checked my gas tank and it is M8x1.25,  what a twit.
The problem with a standard M8x1.25 is the bottom of the head isn't really flat and there is not much of it to get a crush washer to do its job. The original drain bolt had a larger head with a machined flat bottom for a good seal.
The "packing" is the copper or aluminum crush washer.
  • Who's Online   1 Member, 0 Anonymous, 1,275 Guests (See full list)
