Looking for Very Early '69/'70 240Z Water Pump, Radiator Cap, Alternator & Front Rotors
Hi,
Looking for these items.
Please PM if you have them.
Thanks!
WATER PUMP
RADIATOR CAP
ALTERNATOR
FRONT BRAKE ROTORS
Edited by hiyabrad
Gramatical Error
I have a pair of used brake rotors like the one in your photo. They will need to be turned, and I will need to mic them to see if they can be turned and then successfully used afterward.
Do you know what year cars were those particular rotors with the square open slots used on?
Hi, I am not the expert on this but I believe they were used through 6/70.
Let me know if they can be turned.
Thank you!
hiyabrad,
I was able to get the thickness of the disks I have measured, and they are right at the wear limit , so if they were turned they would be even thinner than the wear limit. They are not going to work for you. Sorry about that.
