  • Replies 16
  • Views 484
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Missed these posts somehow. They're exhaust manifold flange studs.  The three on the bottom.  I felt so proud after getting them out that I keep them around.  Rub them for luck.  The holes are dr
  • By the time I find myself sitting in the garage doing nothing the computers will be implanted in our heads.  I can't wait.
  • Okay, I'll bite.  What'n the hell are those, differential plugs?
Posted Images
Mine is from Facebook.  But, you can change it here as well.  Just click on the Profile option from your name in the upper right.  You'll see a little gray icon that will allow you to upload your own photo.
I don't even feel dumb.  That looks like the only way to do it and it's hidden about as well as it can be hidden.  Weird that there wouldn't be a spot in the Profile section.
Thanks.
Do you have the option to do it?  I may need to check permissions..
2 hours ago, Zed Head said:
It worked after I made it smaller.
I wanted it to be a surprise though.
Great, I'm glad you were able to get it working.
My guess is they are the male brake line end fittings that go to the front calipers.
Kinda hard to see them after zooming in on them, just got blurry.
Edited by rcb280z
Relatively clean threads on the bottom end, hole in the center, I'll guess the metal portion of a couple of very old, very difficult to remove spark plugs. Looks kinda like someone used a pipe wrench on them. I right clicked on the pic. Google thinks they're earrings. Threaded earlobes?.
Now that would say "Mechanic"!!!
I'm with rbs280z, sure looks like brake line end fittings that saw too many ViceGrips
They're exhaust manifold flange studs.  The three on the bottom.  I felt so proud after getting them out that I keep them around.  Rub them for luck.  The holes are drilled completely though to get PB Blaster in behind the threads.  One of them would only budge when the manifold was hot from a torch.
Recently Browsing 0
