All
Today's adventure in Parts Hunting starts at the center console of a '77 280Z.
Attached thereto is a "Fasten Seat Belt" light fixture, located on the upper vertical panel, just below the radio. It is this fixture that is the subject of the following questions:
Hope no.1:  Was there, in any model, an instance of a blanking plate for that hole size? If so, does anyone have one they would part with?
Hope no.2:  Does anyone have a "Seat Belt" fixture housing (bulb holder not required) they would part with?
Hopefully,
https://www.classiczcars.com/topic/61258-details/
33 minutes ago, ensys said:
All
Hopefully,
If you are talking about a replacement seat belt fixture I might have one.  As far as a blanking plate,  I would imagine you would have to make one or replace it with a switch of sorts to power something  else.
https://www.classiczcars.com/topic/61258-details/#findComment-563725
Well, if one is picky, the issues of texture, edge finish, and attachment make a respectable fabrication unlikely.
The blanking plate offers the best opportunity for modification that looks like it belongs without making an irreversible change to originality.
Speaking of blanking plates, I find I also need the square one in the middle of the same grouping.
Thanks.
https://www.classiczcars.com/topic/61258-details/#findComment-563816
  • Who's Online   1 Member, 0 Anonymous, 1,503 Guests (See full list)
