8 hours ago, grannyknot said:
Thank you Santa.
Take a piece of clear packing tape and put it over the face of the pressure gauge. When it gets fogged up from over spray to where you can't read it, replace with a new piece. If need be, clean first with paint thinner, which won't damage the plastic face on the gauge
  • Thanks 1
2 hours ago, siteunseen said:
It's HVLP?
It is considered a HVRP ,  high volume reduced pressure gun. Apparently most HVLP guns require 12-14 cfm from the compressor, mine tops out at 11.7cfm so this DeVilbiss FLG5 only requires 9.8cfm and comes with a 1.4 and 1.8 needles and caps.  Should cover the use of 2k primmer, single stage, base and clear. Now I just have to learn how to paint:unsure:
  • Who's Online   2 Members, 0 Anonymous, 1,056 Guests (See full list)
