Not round but “more round” than the inside diamond shape. The bottom groove in the crossmember and the top clamp on that side are smooth and allow the rack to slip a little. The purpose of the u-clamp and the rubber stopper “lock” the position along with the upper bushing clamps.
Or that’s what I’m going with anyways..!
Well the spare firewall plates arrived today so I got to work!
First a picture of the problem. The current jig puts the column down and to the right.
Next step was to carefully grind off the welds and free the collar from the plate. Then I bolted the firewall plate in, then slid the collar over the steering column. I then bolted the column into the proper position with no strain. I then slid the collar thru the firewall plate and tacked it into place with my welder.
I then pulled it all out again and ground down the ugly welding and media blasted it clean.
and because I can, I decided to powder coat the finished amended firewall plate.
Now to get this back off to @silverminemotors for making the next set of power steering firewall plates!
  • 4 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 1,263 Guests (See full list)
