Finally got to try out my new favorite tool - Eastwood's Contour SCT ....
I figured this old previously repaired driver's door would be the perfect test panel...
before ...
Literally 5 minutes later ....
Easily could have removed all the filler on the lower door in about two more minutes.  I didn't bother since I am planning on re-skinning the lower section anyways ...
The Contour SCT rocks - buy one ....
Edited by ConVerTT
An old mentor used to say "re-skinning a door is part of the basic skill set..."  So here goes  ...
Ground off the edges with a 40 grit flap disk - easy peasy
Decided to cut it just below the body line since there will be some filler required here anyways ...
Cut it with the air powered body saw and a cutting disk ....
Inside is about what I expected ....
I didn't have all my PPE available to bead blast the door so I just hit it with shop vac, wire wheel and a bit more Contour SCT ....
Next up - fit the door frame to the car.  That will be a huge test since the floors and inner/outer rockers have all been replaced.  Guess we'll find out if it's all straight LOL....
So far so good ....
grrrrr - TABCO ???.  That will need to be fixed ....
Inside looks good!
With the fender on ...
grrr -TABCO ????
But the rest is workable ...
Next up - same drill on the passenger side ...
Edited by ConVerTT
  • Who's Online   0 Members, 0 Anonymous, 1,491 Guests (See full list)
