Motorsport has joined forces with KONI to create an exciting new product, one of the most requested upgrades for early Z-Cars we've had, to replace (and improve upon) the departed Tokico HP & Illumina Adjustable Struts. Completely new, constructed specifically for 70-83 Datsun 240Z, 260Z, 280Z, & 280ZX, these externally-rebound-adjustable, twin-tube low pressure gas-charged KONI Sport (Yellow) Struts are designed for use on both stock & modified street cars, as well as autocross & track day cars. Built to give a good balance of street ride quality and handling at the softer end of the adjustment range, the KONI Sports can easily be tuned up to nearly double the rebound damping force for more aggressive control needs: simply open the hood or rear hatch and turn the KONI adjuster knob. Not only can you tailor the struts to your local road conditions (and to your taste), you can also quickly and easily change the settings for a blast at a weekend autocross or mountain run, then easily re-set them for a relaxed ride home. Whatever suspension behavior you need is literally at your fingertips. Also, if you race on different tracks and race conditions, the adjustable damping gives you an edge in setting up your car specifically for any track or autocross course. Koni believes they will work great with Eibach Springs, and will be fine with even lower springs, as long as a proper bump stop is utilized. Let us know if you have any questions, James@TheZStore & I will get you an answer.
The first shipment, for 70-8/74 240Z & Early 260Z, is expected to arrive in the U.S. this March. We expect to receive the 9/74-78 Late 260Z & 280Z Struts 3-4 weeks later, and then the 79-83 280ZX Struts/Spring Seats 3-4 weeks after that. To reserve your set from the first shipment, the Pre-Sale is on now at https://www.thezstore.com/page/TZS/CTGY/classic20b04
https://www.classiczcars.com/topic/61543-koni-sports-for-classic-zs/
  • 2 months later...
  • 3 months later...
Our apologies to all of the patient 280ZX owners, sorry for the delay, as Koni had to spend some extra time on the more-difficult-to-create rear units to make sure they were right. As far as we can tell, they went into production in mid-July. After that, sea freight generally takes about 6 weeks to arrive to Koni in the U.S., and then from Koni U.S. to our warehouse about another week or so. If all goes according to plan... then hopefully that means we'll have them in stock sometime after mid-September.
We hope to have images soon, and of course will announce it here when they arrive.
280ZX's are awesome!
Just a pic. of my rear 280zx 2+2 shocks.. these are the Original 40 year old still good working ones.. Cleaned them up around march 2019, then i heard that KONI is going to make new ones.. oh well.. test these first and can install new ones any time later!
  • 3 months later...
Oops... Guess what arrived in September just like we said? Our apologies for saying we'd announce it when they arrive, and then neglecting to...
Here they are! The front 280ZX cartridges look and function basically the same as the 70-78. However the rear shock/spring seat version features a little extra. Note that these are designed with a 3 position spring seat perch. So if you know you will be touring often with lots of luggage and want a bit more ride height, you can set them to the top position. If you want them to ride a little lower, set them to the bottom position (they are set during installation, to change the position later, the struts must be removed). Nice little option to have available, thanks Koni!
We hope they were worth the wait for your ZX!
