Good results!
So was there a thread here on the forum where you were working on fixing the WOT lean out problem with the SUs? I don't remember such a thread, but that sure doesn't mean it didn't happen.    LOL
Yes
I am going to give them a try. Have them on order
72 body and block, everything else 71, Tokico springs, Illumina, R180 CLSD, 83 close ratio, 3.90 gears, Ztherapy SUs, BRE 15X7 Libre wheels and BRE front spoiler.
No, CO, I did not create a thread about this in the past.  I read other threads about fuel levels, fuel pressure, etc.  I even learned how to rebuild SUs and bought old sets, rebuilt them and sold about 15 sets on eBay!  I learned a lot about how they worked, but I could never get my SUs to attain desired performance on my Z.  I guess after a while I just decided to live with it!  My triple Weber adventure taught me that I can get more from my Z than what I was able to get with SUs.  There had to be something I was missing, that other people were able to attain great results with SUs and there was no reason I could not either.  So, pursued a variable I thought would make a difference and solve my problem; needles that allow more fuel on acceleration or WOT!
Edited by duffman
How many turns down for the mix nuts with the SB's?  I tried SM's for my modified 240z engine but found I had to drop the mix nuts a couple of extra turns to get it to idle, which made it way too rich at midrange, fouling the plugs. That's because the SM's (and other British needles that fit, as far as I know) are 0.099 at station 1, compared to 0.090 for the stock Hitachi needles, like N-27's. When I installed a modified 280/280zx engine, the first needles I tried were modified (richer at mid-range and top end) N-27's. Looks like my AFR numbers are about where the engine builder wants them so I guess I lucked out.
Checked my book, it shows SB's same as SM's at the top two stations, then they start to lean out more than SM's like you said. Anyway, your AFR numbers look OK, so however it works, it works. I've read where someone planned to drill out the nozzles to use British needles. Have also read about pushing the needles up into at piston as far as they'll go which is about 1/8" or 1 station higher than FSM says to put them. But that would only get you to 0.095 at the top station (if my 1/8" measurement guess is correct), not .090.
