6 minutes ago, Diseazd said:
You don’t have to disconnect the steel lines from the master cylinder to install the disc. Just take off the two nuts holding the m/c to the master vac and carefully pull it away from the master vac. Pull out the plunger/adjuster shaft. Super glue the disc to the back of the plunger/adjuster shaft and reinstall in reverse order.
I plan to pull this apart tonight to see if the disc is missing. Since getting feedback on this thread I have watched a couple of videos on the purpose of the disc. I still don't understand how it could have been lost without my having initially worked on the booster or master cylinder, but I have looked at every other aspect of the brake system. Thanks for enlightening me to this possibility. Jerry Purcell
Edited by JLPurcell
Once you take the plunger pressure off the disc, they sometimes just fall into the body of the booster.
If you see it is not where it should be you might try pulling the booster off again shake it a bit and if you hear something bouncing around in there you can usually bounce it toward the opening and get it out.
4 minutes ago, Diseazd said:
Charles is sending him another......a lot easier to just use that one. A loose reaction disc won’t hurt anything if it just stays in the booster IMO.
I did not intend to imply it would affect anything. Just a plausible answer as to where they typically end up.
Charles, thank your for your input. Together members of this site are the brain trust on Z cars. I used to think that I was an expert on these cars, but sometimes the members of this site make me feel wanting for Z knowledge. I just hope that I can share something from time to time that helps someone. JLP
21 hours ago, JLPurcell said:
No, I did not do anything with the booster or the brake master until the change of the front calipers at which time the problem emerged. I then sent out the brake booster for inspection.
Since this is the case I would rule out the reaction disc from the initial installation. Also in my case the missing reaction disc caused the opposite brake condition.
My brakes became very touchy and want to grab with little pressure on the pedal. The normal modulation was gone.
See what you can find. I do have another suspicion based on what you describe as well.
I am all ears, I have removed the brake master cylinder and taken it apart. I have removed the booster and there is a black rubber disc on the front of the plunger, ( am still looking forward to comparing it to the one Charles is sending). So at this point I am still searching and thinking of a total run through of the remaining system. Ideas?
On 3/9/2019 at 10:47 AM, JLPurcell said:
today I started the car and felt for vacuum has vacuum in houses to the brake booster and holds vacuum after engine is turned off. Any suggestions? I am my end on this problem. Thanks for any help!
Can't tell where you checked for vacuum.  Is it possible that the check valve is in backwards, or that something is blacking vacuum from the booster body?  Or maybe something is bound up in the booster itself, not letting the vacuum do its thing.
Wow.....Sorry Jerry.....just seemed like the symptoms I had with a reaction disc. Pedal hard as a rock but had to stand on the pedal with both feet to stop.
Did you bleed the lines while doing all of this by pumping on the master cylinder?
Have you checked that the master is still functioning properly?
Could it be that your master has failed?
I am at wits end at this point. There are only a couple of components in the system at this point. Brake warning light switch and valve in rear brake system. I don't believe that it can be the rear brake components they have not been touched since working, and The front is back together with all of the original parts at this point. Just leaves me scratching my head. I was so hoping that the disc was the problem. JLP
Have you checked the direction of the booster check valve as suggested above?
I am scratching my head as to how the problem could be anything other than the booster or vacuum feeding the booster. In my experience, pretty much every other negative situation in the brakes leads to a soft, spongy, whatever, pedal. I suppose if a wheel cylinder were frozen solid the result would be a harder pedal but...
If you block the booster vacuum entirely, does anything symptomatically change in the way the pedal feels?
Definitely check the direction of the check valve. If it is backwards, it will feel like no booster...thus hard pedal.
Even though the pedal is hard, does the car stop as it should...assuming you give enough leg effort?
