Is that not the narrow band O2 sensor location from a ZX manifold?  Never seen an early manifold with a need for either an EGR fitting or O2 sensor that would explain that hole. Unless it was a later user added "feature"
Anyway if its O2 bung thread, its M18x 1.5.
https://www.google.com/search?q=280zx+exhaust+manifold&rlz=1C9BKJA_enCA668CA668&oq=280zx+exhaust+manifold&aqs=chrome..69i57j0l3.6099j1j7&hl=en-US&sourceid=chrome-mobile&ie=UTF-8#imgrc=wbMsjPBtTsxSnM:
Edited by zKars
https://www.classiczcars.com/topic/61837-need-a-plug-bolt/#findComment-571183
Right you are Jim. It’s not an early manifold, it’s a manifold from a ZX with no exhaust tubes......W48. I tried 3/8 and 1/2 inch plugs.....one too small and one too large. I just want to plug it. I’ll order an M18x1.5 plug. Thanks so much for your help.....I am always impressed with your knowledge of Z cars.
Regards
Guy
https://www.classiczcars.com/topic/61837-need-a-plug-bolt/#findComment-571187
Regards
Guy
They will probably have one at your local big box parts store too.
https://www.classiczcars.com/topic/61837-need-a-plug-bolt/#findComment-571190
1 hour ago, zKars said:
Glad to help.  Speed shops that sell weld in O2 bungs will also have plugs. Some of the bungs I've bought actually came with the plug.
Great....I just ordered 2 bungs with the M18x1.5 plugs. One for each of the two Stroker Motors (I’ll have them welded in the Dow pipes). Curious as to how the A/F ratio is with the SU’s. Have you ever checked your Stroker with the SU’s? If so, what were your numbers?
https://www.classiczcars.com/topic/61837-need-a-plug-bolt/#findComment-571215
2 hours ago, zKars said:
I had a great experience with my SU's with the stroker motor. Nearly equal performance in the low/mid range as the Mikuni 44's I had previously, excellent mileage, easy starting etc. AFR's with N47 needles on cruise at 15'ish, 12-13 at WOT
Perfect.....Yes I love the way the strokers pull with the SU’s and their simplicity. Just didn’t know if they were lean at WOT.
Thanks
https://www.classiczcars.com/topic/61837-need-a-plug-bolt/#findComment-571240
  • Who's Online   1 Member, 0 Anonymous, 1,513 Guests (See full list)
