Threads on the captive nut at the right-side end of the transmission mount are in lousy shape.  I tried to tap out the hole but it still looks ugly, and the bolt  won't go in smoothly. I don't think I've got much left there.  So my question is if install hel-coil, will it be strong enough to withstand the torque of the transmission?
Many thanks
https://www.classiczcars.com/topic/61859-transmission-mount/
Thanks Granny (as always).
The new bolt was always in the cards.  8.8 grade and bigger head (yea I know, it's not original, but who else is going to be crawling under the tranny?).
"Time-cert" is a term I'm not familiar with, but will be looking it up asap.
Best regards,
