Hey Captain, is this the one? Only £8 on fleebay, shall I hit buy?
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F163516321436
8e1e6c857d447c7a9d11386f25982a5b.jpg&key=4b448ced4211e72da64f8d1e3563d909a338068d22d5e9e0876d483f7ffd8432
And then there is the SUPER grey, so which is best!?
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F184243311437
Neither of those are what I recommend for gasoline intensive applications. Both of those are the grey RTV silicone that I used to use everywhere before I discovered the MotoSeal. (The Ultra Grey is what they cell it here. And from what I can tell, the "Supra" (not Super) is what they call it elsewhere on the globe but it's the same RTV.)
I took a look at ebay UK and found the stuff, but I didn't find anything IN the UK. It's all shipped from the US or Lithuania. I'm guessing they don't sell it in the UK.
Here's a pic from your ebay of the MotoSeal:
And another pic of the same stuff in a different package:
The trick is that the Motoseal is not an RTV (like the Ultra or Supra Grey stuff). Instead, it is a solvent evaporation cure based sealant and not a silicone.
Once the solvent evaporates, the rubbery solids remains are not particularly soluble in gasoline. According to the MSDS, it mostly uses the following:
XYLENE
2-BUTOXYETHANOL
ETHYL BENZENE
If you can't find that brand name, there's got to be something within your shores that is similar. Finding it is the trick though.
Here's a popular one.  I read about it for use with transmissions.  You can disassemble easily if you make a mistake, so I got some.  It ends up as a very thick goo after it dries.
The solvent, or carrier fluid, smells like ethanol (in the Hylomar Blue).  Says fuel resistant.
http://hylomar.com/hylomar-product-range/gasket-jointing-compounds/
Edited by Zed Head
Glad to help. To summarize the sealant the sealant stuff... I've never seen a silicone RTV sealant that said it was recommended to be used in a gasoline environment. All of the ones I've looked at say "not for head gaskets or for contact with gasoline". And while the RTV stuff won't instantly dissolve or burn down, fall over, and sink into the swamp... You can do better.
I tried that Motoseal stuff because the package actually said "Gasoline resistant" on it and I've been satisfied in those applications. I'm sure there are other options.
All that said... I would NOT use the Motoseal between your carb domes and the bodies. I'd be worried that it would work TOO well and you wouldn't be able to get the domes back off easily. For that application, you want something that doesn't work "as well".
