Hi All,
Jump into front air dam and rear spoiler. Neither purchase can with any hardware or instructions (I do read them), just the unpainted part. Air dam, can't mess that up but I was curious if there is a standard or proper location for the rear spoiler? Checked out a ton of pics, Is the answer flush with the hatchback lip? or should there be a space forward of the lip?
Rear spoiler 432 style, two mounting bolts.
Any diagram or advise would help.
https://www.classiczcars.com/topic/61929-rear-spoiler-fitment/
here's my rear spoiler as mounted from the dealership in 1972.  It's mounted right before the hatch rolls down.  That was one of the hardest things I've done that I thought would be easy.  Take the vinyl cover off the interior side bottom of the hatch to access the bolts.  Getting the nuts on are a huge pain in the rectum.  Good luck!
Not my car but the 432
google search...
https://www.google.com/search?q=mounting+rear+spoiler+classiczcars.com&rlz=1C1BOFA_enUS494US494&oq=mounting+rear+spoiler+classiczcars.com&aqs=chrome..69i57.11718j1j7&sourceid=chrome&ie=UTF-8
Edited by siteunseen
10 minutes ago, siteunseen said:
If I ever do it again tape will be used.
I did put rubber fender washers under the bolts. Keeps the spoiler off the paint.
Good point on the rubber washers Site. I used rubber “O” rings under each bolt......not only does it keep the spoiler off the paint, but allows water to pass through for drying purposes and by sealing the bolts, it keeps water out of the holes in the deck.
Great minds and all that jazz... I too used small "O" rings to seal each of the six bolts when reinstalling my spoiler.
  • Who's Online   2 Members, 0 Anonymous, 1,444 Guests (See full list)
