16 minutes ago, siteunseen said:
So did I "did or didn't" help? I hope i did at least get a second look.
I think he ended up in the right place so that's what matters.  My rambling probably caused confusion.  He's probably tooling around the countryside right now...
  • Haha 2
14 minutes ago, Mark Maras said:
Something else struck me as odd along with these timing issues. In post #13 after adjusting the valves, cylinders 1-5 were at 130 and #6 was 120. To my knowledge, those #s should be up around 170 or so.
The gauge used can have a big impact.  I have a gauge with a long tube to use as an extension.  That extension drops it down to the 130's from 180's.  Adds to "effective combustion chamber" volume.
I wonder if he had the throttle wide open.
 I thought about the throttle plate. I didn't think about the long tube entering into the scenario. Both logical explanations but why is #6 10 lbs. lower? Maybe that was the first cyl. checked and it didn't have oil pressure yet?
20 hours ago, Zed Head said:
It would mean more with a video of the engine running...  Or at least tell us what happened.  You never said.  Saga incomplete.
Yes indeed!
Basically it was a combination of valve lashing and the oil pump install instruction diagram in the FSM not telling you which direction is the front of the engine. I installed the oil pump mostly correctly, but I was one tooth off, and that threw the timing out of wack.
  • Who's Online   2 Members, 0 Anonymous, 1,059 Guests (See full list)
