siteunseen Posted April 6, 2019 Share #25 Posted April 6, 2019 That's funny!!!! Link to comment https://www.classiczcars.com/topic/61948-rebuilt-engine-wont-first-start/?page=3#findComment-572731 Share on other sites More sharing options...
Zed Head Posted April 6, 2019 Share #26 Posted April 6, 2019 16 minutes ago, siteunseen said: So did I "did or didn't" help? I hope i did at least get a second look. I think he ended up in the right place so that's what matters. My rambling probably caused confusion. He's probably tooling around the countryside right now... 2 Link to comment https://www.classiczcars.com/topic/61948-rebuilt-engine-wont-first-start/?page=3#findComment-572732 Share on other sites More sharing options...
Mark Maras Posted April 6, 2019 Share #27 Posted April 6, 2019 Something else struck me as odd along with these timing issues. In post #13 after adjusting the valves, cylinders 1-5 were at 130 and #6 was 120. To my knowledge, those #s should be up around 170 or so. 1 Link to comment https://www.classiczcars.com/topic/61948-rebuilt-engine-wont-first-start/?page=3#findComment-572733 Share on other sites More sharing options...
Zed Head Posted April 6, 2019 Share #28 Posted April 6, 2019 14 minutes ago, Mark Maras said: Something else struck me as odd along with these timing issues. In post #13 after adjusting the valves, cylinders 1-5 were at 130 and #6 was 120. To my knowledge, those #s should be up around 170 or so. The gauge used can have a big impact. I have a gauge with a long tube to use as an extension. That extension drops it down to the 130's from 180's. Adds to "effective combustion chamber" volume. I wonder if he had the throttle wide open. 1 Link to comment https://www.classiczcars.com/topic/61948-rebuilt-engine-wont-first-start/?page=3#findComment-572734 Share on other sites More sharing options...
Patcon Posted April 6, 2019 Share #29 Posted April 6, 2019 Or if the engine hasn't been run in a while the numbers could be low from that too, but I suspect the throttle plate is a pretty good guess. 1 Link to comment https://www.classiczcars.com/topic/61948-rebuilt-engine-wont-first-start/?page=3#findComment-572736 Share on other sites More sharing options...
Mark Maras Posted April 6, 2019 Share #30 Posted April 6, 2019 I thought about the throttle plate. I didn't think about the long tube entering into the scenario. Both logical explanations but why is #6 10 lbs. lower? Maybe that was the first cyl. checked and it didn't have oil pressure yet? Link to comment https://www.classiczcars.com/topic/61948-rebuilt-engine-wont-first-start/?page=3#findComment-572743 Share on other sites More sharing options...
CaptainMajestic Posted April 6, 2019 Author Share #31 Posted April 6, 2019 Thank you all so much for all your help! Link to comment https://www.classiczcars.com/topic/61948-rebuilt-engine-wont-first-start/?page=3#findComment-572763 Share on other sites More sharing options...
Zed Head Posted April 6, 2019 Share #32 Posted April 6, 2019 38 minutes ago, CaptainMajestic said: Thank you all so much for all your help! It would mean more with a video of the engine running... Or at least tell us what happened. You never said. Saga incomplete. 1 Link to comment https://www.classiczcars.com/topic/61948-rebuilt-engine-wont-first-start/?page=3#findComment-572766 Share on other sites More sharing options...
CaptainMajestic Posted April 7, 2019 Author Share #33 Posted April 7, 2019 20 hours ago, Zed Head said: It would mean more with a video of the engine running... Or at least tell us what happened. You never said. Saga incomplete. Yes indeed! Basically it was a combination of valve lashing and the oil pump install instruction diagram in the FSM not telling you which direction is the front of the engine. I installed the oil pump mostly correctly, but I was one tooth off, and that threw the timing out of wack. 1 Link to comment https://www.classiczcars.com/topic/61948-rebuilt-engine-wont-first-start/?page=3#findComment-572832 Share on other sites More sharing options...
