Has anyone got any links to any good 2.7(ish) engine builds?
I'm going the hard way about it(140mm rods etc) however looking forward to having something a little from the norm.
I've got the last few bits on the way now so would like some interesting reading/research.
Edited by Jason240z
https://www.classiczcars.com/topic/61952-27-engine-builds/
2 hours ago, riceburner said:
Thats a lovely build there.  He builds the best L series in the world though(probably!).
I'm
+3mm pistons(29mm pin)
280 crank
140mm rods
so a lot more conventional.
https://www.classiczcars.com/topic/61952-27-engine-builds/#findComment-572671
  • 1 year later...
I just fitted a stroker I built many years ago. Used a standard l24 block, l28 crank, l24 pistons and rods. Shaved the difference  in the rods off the top of the dished pistons which ended up as flat tops. E88 head with some port work and mild can. Still running in but can feel a big improvement over my old stock l24.
https://www.classiczcars.com/topic/61952-27-engine-builds/#findComment-610743
  • Who's Online   1 Member, 0 Anonymous, 1,081 Guests (See full list)
