I purchased a new radiator on amazon for my 7/71 240Z that actually looks quite nice.  The problem is there are two ports at the bottom of the radiator.  The ports are 14MM threads.  I went to every hardware, auto, and home improvement store to find a cap that would screw on to cap the holes, but they're not made in metric.  I believe the ports are for a 280Z.
Any suggestions as to how to cap them?
Amazon.com: For Datsun 240Z & 260Z Full Aluminum 2-Row Racing Radiator - Nissan S30 Base 2+2 Coupe: Automotive 2019-04-08 08-22-18.png
To be clear, the channel between the two ports does not affect the rest of the radiator, correct?  I'm kicking myself for not checking that.  If that's the case, I will put some RTV in the holes.  Thank you for your insight.
  • Who's Online   1 Member, 0 Anonymous, 1,544 Guests (See full list)
