Same problem with the mounts here too. I ground mine down to a half circle looking pin. There's enough in the hole to keep them in place. From what i read the mounts now are all universal and work fine on 280s. 240s need some massaging. Mine were Beck Arnleys. Good luck.
Which parts are not aligning?  I left all of my nuts and bolts loose and a pointed chisel as a drift pin to align the motor to mount holes to get the bolts through.  My problem was the motor to mount alignment.  The locating pin to mount stud distance was fine.
  i didnt see any alignment issue (not to say there isnt another issue). Right now my comment is regarding the pilot stud. It is to far from the bolt. I probably should have removed the washers for the picture.
Edited by Sailor Bob
2 hours ago, Zed Head said:
I remember some of those threads.  I think that my motor mounts are Anchor brand, from Oreilly auto.  There are others.  Brand was a question.  Mine had screwed up threads on the studs.
Im seeing a trend here. Oh well, lots of posts with complaints coming, cause theres lots of replacement parts.
  • Who's Online   2 Members, 0 Anonymous, 1,536 Guests (See full list)
