On 5/15/2019 at 1:59 PM, moritz55 said:
Well the linkage finally arrived but with 2 issues: the linkage is a littlr bit shortet than my stock one and one of the plastic ball ends is cracked. However the other end is fine. Is it recommendable to unscrew on of the ends and install it on my stock linkage? I will need to use a dremmel to sand the worn zinc plated scratched finish also. Anyone?
