Regarding the idle issues and settings----if you haven't used it.
260Z Carb Adjustment Manual (1).pdf
With the flat tops you need this and I would stress that you follow it exactly from beginning to end. It should resolve any issues.
(Don't worry that it is labeled 260z carb adjustment---they are essentially the same as the 73 version)
