Interesting, I got a light gun stock stain but now reconsidering using it after your comment. Maybe I’ll test a small area first with plain polyurethane. After sanding the resin wheel portion it had a nice light straw look and when I rinsed it off it got surprisingly dark while moist. Maybe the polyurethane will act the same but with a shine. Will post my results later today.
12 hours ago, bingo said:
I think the "wood" on the steering wheel is actually a resin of sorts that looks like wood. I would be surprised if it accepted stain or other treatments made for wood.
The rim is wood impregnated resin - it readily accepts stain.
1 hour ago, Jaymanbikes said:
Did you apply polyurethane afterwards?  Red Mahogany is the color I recently purchased but was afraid it would be too dark.
I applied multiple coats of lacquer that held up for about 5 years.  Ultimately the oil from my hands caused a breakdown.  Its time to redo it, will likely use poly.
  • Who's Online   2 Members, 0 Anonymous, 1,433 Guests (See full list)
