I searched a number of times, but couldn't find the answer to my simple question.
When installing a mechanical fuel pump, how is the Permatex -  "Permatex 85420 Permashield Fuel Resistant Gasket Dressing & Sealant", applied?
Is it applied to each of the four hard surfaces? OR, each side of the two gaskets?
Roughly, how much is used on each surface?
Also, do I lubricate the pump before installation?
Any help is appreciated.
Edited by wadelester
 Your choice as to which surfaces get the dressing. A thin coating is all you need. Any more than will result in dressing squeeze out. I've installed pumps with no dressing, just a bit of grease on the gaskets and had no leaks. No need to lube the pump.
