Hi,
I have a 76' 280z (steering wheel mounting hardware looks identical to your photo above), and the horn pad is triggered by a smaller copper spring in a rigid rubber tube under the horn pad mounting bracket.
I know there are some changes between 75/76 and 77/78 model years, so the horn functionality of your car may be different than mine.
I believe the wire is for the 240z steering wheel and horn pad mounting bracket. Is the parts illustration exploded diagram above for a 240z or 260z?
Try checking the fuse box first if you haven't done so already. I think it's a 10A fuse for that slot, but check the 1977 z car FSM to be sure.
Here's a link to download it for convenience:
Then check for the actual horn itself to be sure it is there.
Then try looking for the little copper spring under the steering wheel horn pad mounting bracket.
I hope this helps.
  • Who's Online   2 Members, 0 Anonymous, 1,444 Guests (See full list)
