The PO installed the fuel pump with no spacer.  I smelled fuel in my oil so I replace pump and installed new spacer.  When I installed the pump I felt a little pressure on the outside of the pump arm.  I seated the pump with a bit of inward pressure as I bolted it in.  I started the car and then let it idle for about 5 mins and then it died.  There was no fuel in filter.  Will not start again.  I sucked some fuel up to fuel filter, then I put hose on the output of the pump and into a bottle.  I cranked the car and no fuel came out.
Questions:
1.  Is the pressure supposed to be on the outside of the arm when installing?  Could I have installed it wrong?
2.  Is it possible for the PO to have done something to eliminate the need for a spacer?
3.  Should I hear the pump?  When it was initially running, I really didn’t hear it (wasn’t paying much attention though)
4.  Was my test with the hose in a bottle a good test?
5.  What next?
Thanks
https://www.classiczcars.com/topic/62250-fuel-pump-with-no-spacer-on-71-240z/
  • Who's Online   1 Member, 0 Anonymous, 1,508 Guests (See full list)
