I hate to start a new thread over something so (seemingly) trivial, but I've search all over and cannot find anything.
I'm replacing most/all of the bushings in my 280z. Some I'm doing urethane, some I'm retaining rubber. It's a street car and I don't want it to be unbearable.
Anyway, I cannot find a rubber transmission crossmember bushing anywhere. Only polyurethane - and this is one area I definitely want to avoid urethane.
Any help is appreciated.
Edited by Kevin McSweeney
That is the mount insulator, like pictured below: https://zcarsource.com/transmission-mount-insulator-240z-260z-280z-280zx-70-83-new-oem
I'm looking for the transmission crossmember bushings, like these: https://www.energysuspensionparts.com/7.1101 except in rubber.
2 minutes ago, Terrapin Z said:
I understand better now. Those are discontinued from Nissan, unfortunately.
You might be better off finding a used mount with bushings in it that are in better shape than yours. JMO
Oh, thanks for the info. I may have to go to urethane then!
With the frame mounts poly, and the trans mount rubber, I would think it wouldn't be too bad. It is a personal choice to be sure. My 70 has no mounts like that, but I don't mind at all.
9 minutes ago, Patcon said:
They're proud of that
Yes they are.
You will feel a little more engine vibration through the trany mount with PU bushes. It's no where near as bad as the mustache bar insulators on the diff.
For street cruising I would keep the transmission  cross member and mustache bar mount original or find a good donor car to replace them like I did. I tried PU on them and now back to the original style
  • 2 years later...
  • Who's Online   1 Member, 0 Anonymous, 766 Guests (See full list)
