 If it was mine, I'd start with removing the #4 valve seal and inspect it for damage. I suspect it was compromised during installation. Swapping out the other seals depends on what you find and the desire to do all of them.
The simple answer is, one of the valve seals (I'd guess the intake valve seal) #4 cylinder is leaking. The surface of the seal that rides on the valve stem is damaged, probably during installation. That allows oil to run down the valve stem and get sucked (intake valve) into that cylinder.
On 5/18/2021 at 10:58 AM, Mark Maras said:
@jalexquijano Everyone agrees there's no need to remove the head to change a valve seal and if you do you may be opening a Pandora's Box of trouble and expense. The compression is good on all cylinders so we know the rings and valves are sealing. The only problem is a fouled #4 plug which, by process of elimination, we've come to believe is a leaking valve seal. Installing one valve seal is a piece of cake compared to pulling and reinstalling the head.
Ok. Dday is tomorrow. Im removing the valve cam and connecting an air compressor to cylinder number 4 to keep the valve from falling. Any caution or consideration i should take in the process. I really need a guide in order to get this thing right change the seals and avoid opening any pandora box, sort of a step 1 , 2 and 3 guide.
  • Who's Online   2 Members, 0 Anonymous, 1,435 Guests (See full list)
