Just now, jalexquijano said:
I talk to the owner of the business and he said that engine was built perfectly.
What else would he say? Those rings have to be staggerd. The oil control ring is a worm ring that has a top and bottom solid ring also.
Have you had this problem all along or just recently?
  I expected that answer from C.D. No crystal ball needed.
 C.D. is a likely person to point a finger at but the question is ,where do we go from here? He's not going to offer any help. If it were mine (I wish), I'd either pay someone with a good borescope to take a look in all the cylinders or buy a good borescope and take a look myself. The cost of either option may be similar, IMO. Looking down the road, I'd also be keeping my eyes open for a used engine.
  • Agree 2
You will get a low number if one of those tube adapters is used in the spark plug hole.  It increases the effective combustion chamber size.  Five 110's and a 100 looks pretty even overall.
Four is the dirty one though and he shows three as the low pressure.  So, bad oil ring seems to fit best.  Bummer.  I'd run a hot plug in #4 to keep it clean.  I think it's been suggested before.
  • Agree 1
49 minutes ago, Mark Maras said:
 We narrowed an ignition problem down to cap, rotor, wire and their connections because it affected one cylinder. I thought we had ruled those out in the beginning. Thoughts?
I know it was discussed but I'm not sure we ever got good enough feedback to rule it all out.
If it were mine I would see if the former 240z racing mechanic had a good dizzy cap and wire setup and swap it all out as a test. Also check #4 plug for a helicoil. Maybe there is too much resistance right at the head
It is CaDatsun after all
Edited by Patcon
 Both are excellent suggestions. As I recall he has a reasonably new set of NGK wires and we tried swapping two wires. He eventually bought a Bosch cap and rotor and verified a hot spark. I hadn't thought of a helicoil.
  • 1 month later...
