It seems the map light only works in one exact position if I push down too far it turns off is that expected or should there be a wider range the light turns on with. It seems like I almost have to wiggle it to get it into the on position
https://www.classiczcars.com/topic/62398-77-78-map-light/
Exactly what mine does.  But then it's 45 years old and rarely if ever gets used. I would imagine there's a brass contact in there that could use a bit of cleaning (de-oxidation)... I've never been motivated enough to see if that cracks open.
https://www.classiczcars.com/topic/62398-77-78-map-light/#findComment-578517
Go on, be brave, grab a philips screw driver, and remove those four flat headed screws holding on the trim cover. Never know what you might find inside....
Then let me know if you need any of those screws cuz you're gonna lose one at least....
https://www.classiczcars.com/topic/62398-77-78-map-light/#findComment-578544
  • Who's Online   0 Members, 0 Anonymous, 1,208 Guests (See full list)
