Alpha I think the problem you mention is something similar to what I had. First do you have an electronic dizzy?
If not replace the condenser & points in the old mechanical distributor.
There both very cheap. Have you changed your coil? The coils are known to pay up after the car has warmed up.
Just a thought.
Its not a problem to buy them at your local autor parts shop, and installing them is pretty damn easy, however, there are usually lots of little plastic spacers/washers, if you don't get them in the right place, and they earth, your car will never start. Just take it easy and pay attention to what goes where, the condenser is also a possibility, when they heat up, they tend to not work well absorbing the extra spark and your car farts and pops when you rev it.
  • Who's Online   0 Members, 0 Anonymous, 1,409 Guests (See full list)
