I now have around 150 miles on my freshly (last year) restored '71 240.  The differential seems quite noisy so I checked the oil level (finger tip reaches oil), then drained it.  No sign of metal filings or debris on the magnet.  I drained it into a four-litre ice cream pail and it only filled it to 15% capacity.  I put in new hypoid lube, but in a 1 litre bottle I've still got 700 ml left with the diff filled right up to the edge of the fill plug.  the FSM says it takes approximately one litre, or .21 gallon.    Just to make sure the oil wasn't all backed up in the diff casing, I left the rear of the car on jack stands and lowered the front.  Very little difference.  I've still got well under half a litre in the car.
I see there was some discussion on this topic in 2011, and people emphasized that actual capacity can vary depending on casting irregularities, but in the case of my car, the difference seems somewhat greater than a casting variation.  Any thoughts?
Thanks,
https://www.classiczcars.com/topic/62453-differential-fluid/
8 hours ago, Richard McDonel said:
Stole a measuring cup from Mama.  What I drained from the seemingly full diff was 16 fl. oz = .47 litre.
I have no idea where to put the other .53 litre.
That is really strange, quite often when you empty the diff there will be be far less than a litre because over the years it splashes out of the plastic breather cap on the top of the cover but not being able to get that full litre in is pretty weird I think.  The only way you are going to solve it is to unbolt the cover and have a look, The paper gaskets are cheap and still available but something like Permatex gasket maker work just as well. Hard to believe casting irregularities could take up half a litre of space.
10 hours ago, wheee! said:
My R200 took almost three litres...
That's because you have that gorgeous finned cover with all the extra oil capacity.
  • 11 months later...
  • Who's Online   0 Members, 0 Anonymous, 1,436 Guests (See full list)
