A 1/2 inch socket drive fits.  I've found that the wobble type get a better bite.  The straight ones slip out easily.
Run a torch flame around the plug to expand the hole.  It's a taper fit, that's why it sticks out like that, and Nissan used a powerful sealant.
  • 3 weeks later...
A 1 inch piece of flat stock about 10 inches long with a 1/2 inch bar stock piece welded to the end. The I/2 piece was measured to allow it to just fit between the mustache bar and the diff for a normal cover. You can also just weld the short piece of 1/2 bar stock to 10 inches of 1/2 stock. The extra capacity cover has a side filler and is somewhat easier to get at with a 1/2 inch extension.
  • Who's Online   0 Members, 0 Anonymous, 1,514 Guests (See full list)
