Hi All,
My early Hitachi radio functions nearly 100% except for the audio output stage.
I get a speaker thump when turning on but no static or sound. The volume and tone controls make no changes to the silence.
I just replaced all caps and no change.  I found the cap C38, which decouples the power amp transistors from the speakers, to be toast and the PO seems to have hooked up two speakers to the output.
I am now starting to investigate deeper. The voltages on the power transistors are normal however I am getting ~230ohms across the input winding of the audio transformer T7 feeding the power stage from the Hitachi FA-6007T op amp.
I'll check against my working radio.
Here are some pictures of cap replacement to help others.
I also included the service manual  (thanks to @hr369 and @JDMjunkies.ch) ?
Sadly there are no AM radio stations in this area so trouble shooting RF stages will be is tough. Hopefully it is just a problem in the audio stage.
Electrolytic Capacitors:
Crusty C38 Cap
hitachi_tm-1081-zb_all_transistor_auto_radio_1970_sm.pdf
  • Like 4
Nice work! 3 decades ago when I used to design /build / fix amps (long story), your best friend was a signal generator and an oscilloscope. Do you have access to at least the latter? It’s the only way to truly troubleshoot a circuit like that. Having said that you are making great progress.
I would say if two speakers were connected, the final stage amp would be fried and the Darlington transistor or pre-power stage op-amp would also be toast. Very often when a power amp / transistor is overloaded, it pulls way too much current on its collector and effectively shorts out what ever is feeding it.
Watching with interest.
Now don’t swear at me but I replaced all the old electronics with new in mine; with microswitches behind the FM/AM buttons so everything looks totally stock and all the knobs switches function as they should but I get 20W RMS x2, half decent sound and connection to my iPhone so I can hear the Satnav over the exhaust [emoji12]. Somehow sad that all that lovely design and beautiful engineering you see nowadays fits on a chip or two.
Good luck and well done for the great trouble shooting to date! It really isn’t as complex as it looks [emoji106][emoji106]
Thanks for the great advice and support!  I still have a scope.(I used to have access to signal generators 30 years ago too). For this, I have just been lazy and have not pulled the scope out yet.  I'm lucky and have another radio that works so I should be able to compare voltages and signals through the system.  If  I can find an FM to AM converter then I will have a 24/7 input source as there are no AM stations here anymore. ?
I think I found a supplier for the very old Hitachi Op Amp but I will scope out rather than throw a grenade and replace. The voltages on the Darlington array match the schematic so I am hoping it is ok.
Please post a link to your radio upgrade to this thread to help others!
You’re most welcome and I would gladly have popped over to help if you were more local ;)
Great that you can still get the original opamp!! At least you can preserve it.
I didn’t wish to hijack your thread so I didn’t post the link before but since you asked ...
https://zclub.net/community/index.php?threads/stock-radio-modern-internals.20247/
It was all done in a bit of a hurry in small increments of time so I didn’t do as good a job as I would have liked, but it works.
This little bad boy sits totally invisibly under my passenger seat and kicks out some serious bass for it’s size. On about 1/4 to 1/3 of its volume setting it perfectly “fills in” what the stereo lacks without being wide-boy, as we say in the UK, read “red-neck”.
https://www.caraudiocentre.co.uk/product_m-in-phase-car-audio-usw10_p-25817.htm
btw your UK website is great. It often comes up in searches and [mention=1359]HS30-H[/mention] has posted superb information on that site for years.  I love his S20 rebuild thread.
Thanks dude! HS30-H (aka Albrech) is our site Yoda! I am forever in awe of / STUNNED by his depth of knowledge (and kindness in helping people out with rare parts).
  • Who's Online   3 Members, 0 Anonymous, 1,390 Guests (See full list)
