Good news!  It was the op-amp Hitachi FA-6007T  that died. I'm not sure if there are any other Hitachi radios using this early bird?
FYI a quick and dirty test of the audio section is to simply touch pin 1 and the radio should hum.
7 hours ago, 240260280 said:
Yes but what's the connection with zclub.net?
From here:
8 hours ago, 240260280 said:
btw your UK website is great. It often comes up in searches...
They are two - completely unconnected - clubs and forums.
LOL Sorry. I corrected entry but left the wrong right in. <<< makes sense right? Fixed now.
Sorry. No I do not have data sheet. I would love to see it too  I think the IC is more than just an op-amp as it feeds back to the auto tuning circuit. See Pin 7's output below.
I will guess that the op-amp function can be substituted with a compatible op-amp but you will loose the auto tuning without developing the associated circuitry to trigger an amplitude lock on a signal or maybe it is a mute while tuning control?
Yup! I Got it!  Haha!!
So not that it really matters, but that's an AF (Audio Frequency) amp, not an op-amp.
Good luck with the repairs. I paid my way through a couple years of college fixing audio-visual equipment. One of the things I learned is that 95% of all failures are blown output stages. Even if the problem does not appear to be a blown output, it might be anyway.  LOL
I bravely swapped bad unit's output stage to working unit and it continued working.  I put working units output stage in bad radio an no change.
I then moved good AF SIP to bad radio and it worked... risky but easy.   I did verify all voltages in power transistors were the same before swapping so low risk in the end.
  • Who's Online   0 Members, 1 Anonymous, 1,442 Guests (See full list)
