@Usain_Boat
Would you do me a favor and note quote in reverse background if possible. It's really hard for me to read it.
You might be able to get a pencil torch if you can't get enough heat too it. When you hold an iron to it, hold it underneath. Remember heat rises and the wires will heat better on top of the iron
Edited by Patcon
Well it's definitely not the prettiest soldering job I've done but it's done and the car runs correctly! I also checked the other splices around it and they were solid but a little corroded so I just put some dialectric grease on them and taped it all back up.
  • Like 3
  • Who's Online   1 Member, 0 Anonymous, 1,584 Guests (See full list)
