Grinding Weld Beads - Recommendations, please
26 minutes ago, 240260280 said:
A must for port and polish, I'm going to stop by on the way home tomorrow. Thanks
  • 3 weeks later...
@SledZ  Can you be a little more specific about the '3M weld grinding wheel' that you use?  They have dozens of products that fall into the weld-grinding category.  Do you have the 3M product number or name?
@240dkw  That wire sounds intriguing.  Unfortunately, it looks like the manufacturer only offers it in 11-lb spools (Cdn $130 plus tax & shipping from KTS Tools).  That's good for commercial shops, I'm sure, but it represents a lot more welding than I need to do (or at least a lot more than I'm hoping I need to do :unsure:).  Other members with more ambitious build programs may want to try it out, though, so thanks for the tip.
That is what I bought. I have some left over of course, would you like me to put some on a smaller spool and send it to you? Price sure has gone up, l think I paid around 80 cdn  about 5 years ago.
Edited by 240dkw
45 minutes ago, SledZ said:
Yep its here on Amazon. I used only one wheel for dozens of long welds. It's a really good grinding wheel.
https://www.amazon.com/3M-1991-Reinforced-Grinding-Wheels/dp/B0002SRLF2
Interesting.  It's promoted by 3M as a cut-off wheel, although they say in the spec sheet that it's suitable for cutting and grinding.  There are 4 sizes (diameters) offered, each with its own centre hole size.  The 3" disc you're apparently using has a 3/8" centre hole.  Does your die grinder have a 3/8" chuck, or do you use a step-down mandrel to adapt to a 1/4" chuck?
  • Who's Online   1 Member, 0 Anonymous, 1,246 Guests (See full list)
