I am using a donor dash for the metal frame so I can understand how best to install without having to tear apart my car. So let start with removing the old dash pad, there are 21 sheet metal screws that attach to hard points and a few other sheet metal screws that while not actually affixed to the pad, the do stick up into the foam. these should be removed so as not to impede the process.
I was able to get19 of the 21 back in, the other two holes I was not able to locate, will have to deal with them after I pull the pad off the donor frame.
https://www.classiczcars.com/topic/62616-280z-vintage-dashes-install/
  • Who's Online   2 Members, 0 Anonymous, 1,488 Guests (See full list)
