If this is a swap, sometimes there are issues with shifter type and trans type. Generally manifest as not fulling engaging some of the gears. the shifter needs to be "clearance" . If the shifter is original to the trans, not an issue. I have heard some problems can happen with 240's as the trans tunnel may need to be clearance again when receiving 5 speeds.
